Beaky
Digital radios are being installed and reprogramed in some agencies. I've heard that the switch might be flipped as early as November.
Thanks Gary. That explains a recent Unitrunker log of Williamson County with only 7 channels in rotation.garyva said:If all stays on schedule, Round Rock will cut over on November 6th, Georgetown on November 8th, and Williamson County (and the agencies for whom we dispatch) on November 13th, with Cedar Park's specific date TBD but right in there somewhere.
There are roughly 14 channels on the analog system. Last I checked ... only seven of them were actually being used. My guess is the new system is using (or capable of using) the other seven channels. The new digital system appears to be using two of the old control channels - 857.9625 and 860.9625. There's little or no voice traffic. I expect the "missing" channels to become active on the new system as users are added.W5TWX said:\you lost me on that statement about there only being 7 channels. What does that mean? Please explain.
My expectations ...W5TWX said:If I understand this correctly, it sounds to me like i'm not going to have to change my control channels on my 396. All I need to do is start searching instead of scanning and try to ID the new talkgroups. Is that correct or not? I'm confused...
Unitrunker said:My expectations ...
During the transition - both new and old systems will be active. I suggest you copy the control channels to a new system but set the system type to P25 or 9600 trunking (I forget the exact wording on the radio).
After that you'll see a mix of new, unknown Wilco talkgroups plus existing, known Austin / Travis County talkgroups on the new Williamson county P25 site.
Eventually, the old Motorola system will go silent.
W5TWX said:If I understand this correctly, it sounds to me like i'm not going to have to change my control channels on my 396. All I need to do is start searching instead of scanning and try to ID the new talkgroups. Is that correct or not? I'm confussed...
