win 500 issues
mikext
For some unknown reason my win 500 program will no longer display the assigned led colors on the same line as the objects that are programmed. Any ideas on how to restore this feature?
K9DAK
Wauconda, IL
Check that your column widths didn't get accidentally changed to cover up that column. Also, right click on a column heading, go down to the Add Column selection, and check that the LED Color entry is grayed out. If it's not, click on it and the column should reappear to the right of the column heading you right clicked on.
Hope that helps . . .
