Win500 error when opening
obilly
Weekie Wachee, Florida
Hello All,
when i open Win500 on my w7 64bit i get this error 4 out of 5 times, when Win500 opens it works just fine.
any ideas?
addresses change with each failure
sadatoni
Lewis Center, OH
Check both the Application Event log and the System Event log. One or both should contain an entry for
the event and details of what executable caused it. To directly run the viewer, Click Start, Run (Type) Eventvwr.Msc [Enter] That should give a clue at least to what's causing the problem.
brian943
Moodus, CT
Same here but different
I get the same here but at random while saving my .500 file or closing the program. My event logs show a nearly constant Bonjour error, an occasional paging warning on secondary hard disk, and an uninstalled printer that daily tries to initialize. Nothing is flagged for win 500. I am wondering if it is a flaky memory stick, or if the random address precludes that.
obilly
hey,
thanks for responses, been hurting my brain on this one,,,,,,can't figure out,,,,must be with Win500 or ftdi software??
obilly
best i can tell win500 not compatible with w7 64 bit and must be run in compatibility mode xp sp2,,,,,suspect time will correct this issue.....JMO.....meanwhile all works ok
sadatoni
Lewis Center, OH
I've only had a couple of times of getting that error on win 7/64-bit while doing a copy/paste operation. I do not run it in compatibility mode.
