Win500.ini
KC2ZHY
Somerville, NJ
Quick question guys: I run my scanner from a remote PC, which when the power goes out or I need to restart it, it automatically loads my feed and Win500 and starts Remote monitoring upon boot-up. Problem is, there are a few settings that I want it to have loaded when it starts up, but they always seem to revert to the default settings and I can't find them in the Win500.ini config file. This settings are the following:
"Compress Audio" reverts to 'enabled' and I want it 'disabled'
"LCD Poll Int" reverts to '100' and I want it at '50'
It's tedious to have to manually change these every time the host PC requires a reset, so I'm hoping someone knows what I have to add to the INI file (or elsewhere) in order to get my desired results.
Thanks!
P.S: If you see this Don, it'd be really awesome if you could integrate IceCast into a future version of Win500 so I can host alpha tags through my RR feed directly and keep Win500 up. Please consider!
