win500 Nationwide freqs
daggit
Nationwide Freqs
Sorry if this has been asked many times but I'm wondering if I'm missing something on finding Federal Freqs in the data base here. I'm in Indiana and started to program all the local Freqs then started on the statewide channels and now looking for nationwide channels that include law agencies. I don't see an option in the data base here for nationwide just states and counties Thanks.
UPMan
In Memoriam
Arlington, TX
Go to the top level of the database (.../apps/db) where the map of the entire US is. Above the map there are 4 tabs. The second tab is "Nationwide Frequencies."
daggit
I just found that out I'm using win500 software I don't see a way to do the in the software there is no other tabs then state
daggit
I'm I missing something? I'm using win500 and programmed my local and statewide frees but I don't see any tab to go to Federal freqs like there is on the data base here. I'm using this with a ws1065
daggit
Need advice on three software programs
I have tried win500, arc and psredit . I'm I missing something? Arc is the only software program that supports nationwide Freqs. I thought I was going to go with win500 second choice was psredit but when I go to the reference data base here there is no option to go to Federal Freqs. Arc seems the only program that gives that option
fxdscon
¯\_(ツ)_/¯
Just used Win500 for that, no problem. They are in there.
Are you sure you have the very latest versions of all those programs?
AK9R
Central Indiana
Daggit, you've started three threads asking basically the same question. Since your problem seems to be with your scanner programming software, I've merged the threads into one thread here.
daggit
Thanks sorry to be a pain but Im getting my new scanner tommarrow and have been spending hours getting familiar with these programs and really like win500 and hate the Arc500 program but it has the features I want. Others have said there is is nationwide freqs accessed through win500 but Im not seeing it. I'm using v 2.08. When I go to the tab to import from RR all I see is an option to go to a state nothing like nationwide freqs. I really want to buy this program. I don't know what I'm missing but on my version there is nothing for nation wide freqs. This is for a ws1065 scanner.
Spitfire8520
Might be slightly less clueless! =)
Colorado
I haven't used the web import feature in many years, but try looking for a "Nationwide" State / Province when you are doing your web import.
flythunderbird
Grid square EM99fh
When you go to File --> Web Import --> RadioReference.com, select 'Conventional Frequencies.' The Web Import box appears. Click Start. Then on the dropdown box that says 'United States,' drop it down and select 'United States' even though it is already selected. Under 'State/Province,' you'll see (Nationwide) - if you don't see it, click the drop-down box and select it; it should be at the top of the drop-down list. Then under 'Nationwide Agencies,' click on the drop-down box and select what you want to import. See the attached screenshot.
daggit
Thank you very much. I was looking for nationwide freqs but was selecting Trunking then looking for nationwide I didn't know you had to select conventional.
