Win500 stopped working... Help!!!
Dustin1967
Carrollton, GA
About a week ago my win 500 stopped working, when I try to log in I get a quick loading screen and then nothing... Any Ideas what's wrong and way to correct the problem?
Thanks in advance
Dusty
Whiskey3JMC
Google-Foo Ninja 4 Hire
Simulcastylvania
As an IT tech I'm obligated to ask...
1629267674547
If no joy after restarting your computer have you tried uninstalling & reinstalling the app?
gmclam
Fair Oaks, CA
1) It will try to load the last file(s) you had open. These files could be "damaged" or missing.
2) I ran into a situation where it could not find the COM port. It is supposed to do this automatically. I switched over to using Win500_Com.exe and that solved the problem. Yeah now I have to manually select the COM port but so what.
What you might try is installing a fresh copy, likely in a new place (directory). Even if you don't install your license, you'll get a 30 day free trial. This will at least see if there is a PC/system issue or just the install you have is running into something.
