Win500 Streaming
baybum
Howard County
My apologies if this is addressed elsewhere...
I have a Pro-106
When setting up remote monitoring, what server or IP address would I push it to?
I have used "streamwebtown" in the past, is there a way to push it to that?
Many thanks,
Mike
rdale
Lansing, MI
As far as I know, it's not a "push" stream - remote computers use your IP to connect to you.
baybum
Howard County
In WIN500, it asks me to put in a "server address".
What address do they want to see there?
NYRHKY94
Brunswick County, NC
Baybum:
I'm sure Don will chime in here soon and correct me if needed, but Win500 is a basic client-server application. You set up the Win500 "server" on your PC of choice and set the port number to the default of 8086. In the Win500 "client" (another PC on your home network or a remote PC at work), the server address would be the IP address of the PC that is running the Win500 server, or the IP address assigned to you by your internet service provider.
If you are using the Win500 client "inside" of your home network, then just use the IP address of the PC running Win500 server. This should connect without a problem. If you are outside your home network and have a router/firewall, then use the IP address provided by your service provider. In this case you would also need to set-up port forwarding in your router software to connect to the PC that is running Win500 server.
In either case, Win500 only provides 1 client connection natively. If you wanted to have multiple client connections you would need to set-up TCMPUX, which Don can explain further.
Hope this helps.
baybum
Howard County
You lost me on setting up the Win500 server.
Where is the Win500 server? All I have is Win500 client.
baybum
Howard County
OK, I think I found it....Remote server is not enabled in the 30 day trial, correct?
That brings me to my next question.
How do I stream my scanner and be able to show the display?
Not control it, just show the display and hear the sound.
KC1UA
This ain't gettin us noplace, we'll have to blast!
Marstons Mills, Cape Cod, Massachusetts
I just grabbed one of these off of eBay for $50.00. Should be interesting.
edit: um...oops, boy did I zig when I should have zagged...sorry folks, wrong thread! :D Admin, please delete...
baybum
Howard County
The "server" box is grayed out. I can't check the box.
EDIT: OOPS! I was mistaken...I can select server.
baybum
Howard County
OK, I can monitor in my house from one PC to another. (server to Client) But I have no sound.
rdale
Lansing, MI
How is the scanner hooked to your soundcard? Can you hear it through the speakers on the main PC?
baybum
Howard County
I'm making some progress...
I now have sound...I'm connected from the earphone jack to the mic on the computer.
There is a significant audio delay between the server (scanner) and the client.
The displays are in sync, but the audio is delayed at least by a minute.
Also, I am using the public (192.168.1.100) address on the wireless laptop client.
What address would I use if I was not at my house and couldn't use the 192.168 address?
rdale
Lansing, MI
You would set your router up to send all incoming connections to .100, and you would use your external IP (whatismyip.com)
n5usr
Bethany, OK
In playing around with Win500 with a friend, we found that the audio can get delayed significantly if the client computer is not very powerful. In our case, my friend has some ancient Via C3 system with too little RAM to be running XP, but he does it anyway... :p When he first connected to me, the first few transmissions were in sync but he steadily and quickly fell behind! By the end of a half hour phone conversation, he was 5 minutes behind!
Even funnier, though, was when he stopped the client. The audio kept playing! Apparently his system was buffering it somewhere internally, and just couldn't play it as fast as it was received. It was rather strange...
I'm not sure if a slow / busy server system would cause any delays. In my case, with a more-than-capable server streaming to my work laptop (XP, Core2Duo Dell) the audio delay is in the milliseconds range, so I'd be looking for things external to Win500 to find the cause of your delay.
A suggestion on finding your external IP: Use something like dyndns.com. You can set up a free account there, and create a domain name of your own (using one of their domains, and a personal identifier - so you could have something like baybum.dyndns.com). Then you run a small program at home (or even better, many router appliances have this function built in) to keep dyndns updated with your current IP. After that, just use the domain name you set up and you don't have to remember the IP or worry about it changing on you.
I just noticed the PM you sent - hopefully you have your questions answered now! :)
