Win96 / Pro96
_jabber_
Toronto Canada
Just received my Pro96 and using win96 to program.I am trying to put the Toronto Public Safety and OPP on the scanner using the software. I notice when using the software it shows the the control channels only as opposed to the data base list which gives control channels and various talk frequencies. When I download to the scanner and go to manual frequencies it only shows the ones which were listed on the win96. Do i enter these manually? I don't seem to be picking anything up. Any help would be appreciated.
Forts
Ontario, Canada
You really only need the control channel frequencies... The scanner figures out the voice frequencies on it's own. A few things to note: Make sure you set the bank type to 'MOT' (as well as the control channel frequencies), and for Fleetnet you set the custom trunking tables. See my sticky at the top of the forum for programming a Pro-96 for Fleetnet.
stircrazy
London Ontario
Don't forget to change the bandplan to single table in the settings when putting in the OPP. For some reason it goes to multi and it needs to be single.
torontokris
Toronto Canada
doesnt it need to be multi for certain towers (toronto)
i mgiht be wrong been a while since i programmed a pro-96 so im doing it off memory
Forts
Ontario, Canada
I too was under the impression multi tables were required for the Toronto tower. I don't listen to Fleetnet that much while in the GTA so I'm not 100% sure.
kirk23
Pierrefonds (West Island Montreal) Qc Canada
yes.. only 40 MOWAT needs to be MULTI-TABLE
i was online with JABBER for over 2 hours last night, sent him my GTA file all worked for him EXCEPT Fleetnet, he couldn't even get a tower to decode to show system or % in manual mode ,
he tried
40- MOWAT
39- KING CITY
37- WHITBY
9- BRITANNIA (MISS)
not any signal on any of their CTL or ALT freqs, & he's in the Black Creek / Weston area (Lawrence & Jane area) and high up in his building, windows face east & west, so he sholud have got something.
i was at a loss to figure out why, when i'm in Toronto it works fine for me.. hope 1 of you local guys can help him out more than i could (i'm in Montreal).
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
he tried
40- MOWAT
39- KING CITY
37- WHITBY
9- BRITANNIA (MISS)
Hope his Mode setting for freq was MO, if not no data will appear in line 4 during manual check if freq is default FM.
_jabber_
Toronto Canada
yea, was def set on mot, everything was entered correctly as kirk stated.
We tried both with multi and single table ( still no luck )
(thanks Kirk for all your help).. I'll keep plugging away at it
kirk23
thank JABBER, but everything else ( TPS, TFS, PEEL) works? right? i haven't got a clue.. somebody on here will figure it out for you.. it's strange cuz that file works in my pro96 when i'm in Toronto..
Kirk
_jabber_
Toronto Canada
Kirk
I am not picking anything up now, not even in searches. I think I will let Durham have a look at it and see if they can come up with any ideas. Thanks again
Forts
Ontario, Canada
Anything on the weather channels? If not, maybe pop the back of the radio and see if the BNC connection has broken loose... Might be a simple fix (hopefully).
torontokris
Toronto Canada
what antenna are u using? the basic antenna sometimes doesnt get any of the towers in toronto area.. although if ur a few florrs up id think youd get something for sure
other then that then sounds like something wrong with the radio
_jabber_
Toronto Canada
Tried using the basic and 800mhz antenna, def something wrong with the scanner :(
Thanks again for all the suggestions
torontokris
Toronto Canada
both the basic antenna and 800mhz antenna are not made for VHF fleetnet reception... nor will they work well.
id think youd at least get something out of them on fleetnet (10-25%).. maybe try a better or outdoor antenna.. you could meet me and ill hook up a good antenna to it and see
other then that maybe something wrong with the radio.. but its weird the 800mhz stuff works
