Win96 Software Problem
MOTORHEAD27
ESSEX
I got a new printer for xmas. Now when I try to upload to scanner ( pro-2096). I get Com port already in use. Something change when I put new printer in computer.
spooney
Indiana
Probably moved you up a number for your USB adapter. Go into WIN96 settings and change the COM Port up one number and see if that works.
MOTORHEAD27
ESSEX
Did not work.
The only com port that works is 3 com port 3. But I don,t know where the data is gonig. Its not to my scanner.
spooney
Indiana
Ok, you have a conflict going on between the two devices that are trying to use COM 3 at the same time. Disconnect the printer, then start WIN96 and connect the cable to the scanner. Then re-install the printer and it should find a new COM PORT now since your scanner is now using COM 3
