DSDPlus Window Locations
garys
Central Texas
I know I can change the size and locations of various windows by editing DSDPlus and FMP24 batch files, but is there a simple way to understand where the locations on the screen
For example, I currently have the current settings for DSD-VC with the following settings,
-wsl1400.210 -wel172.522 -wcl1528.
Changing those values should move those windows around on the display, is that correct?
Also, is it possible to change the window locations for the FMP24 windows?
I looked in DSDPlus.txt, but it's not overly clear to me how those values can be changed to move the windows.
Thanks.
mattwillson
Move everything where you want it, then click the event log to make it the active window, then type w. That should show you the location values to add to the .bat file.
garys
Central Texas
I did that, but got no results. Maybe I'm just looking in the wrong place. Where should that information appear?
mattwillson
Fastlane must be different, I'm using the free version.
garys
Central Texas
Fastlane is very, very different. I appreciate your help, nonetheless though.
PDXh0b0
Woodland, WA
Google search MPos - Mouse Position
It's a zipped portable(no install required)
This is what one of my bat files look like using two dongles
cg
Connecticut
When the .BIN file was added in v2.18, it added the program's ability to remember location and size of windows upon closing. most of the location settings were removed.
If you search the Notes file for "DSD+ v2.18" you can read the version changes
garys
Central Texas
Thank you, Chris. That explains a lot of the changes since I last used it.
