Wires-x analog node
WX5812
Fort Worth
I’m looking at getting a hri-200 and have a wires x analog node. There is digital around my aera but no analog. I’m assuming you can connect to the same rooms as digital can? The manual says you can use any radio that has a discriminators audio connection so would a maxtrac or something cheap like that work?
ko6jw_2
Santa Ynez, CA
Do not assume that you can connect to the same rooms. Many rooms are digital only. You will not make any friends by trying to connect analog.
wrath
I know several guys who played the lonely road of analog nodes ,using 710s and other non digital radios ,who out of boredom and frustration gave that up very quickly ,if you have an HRI, get a 400 and be full digital node ,there isn't enough demand for digital realy yet in fusion ,they have only recently with deep discounting and features moved alot of radios ,if you go"all in " there's nothing in the fusion world not open to you and your friends via your node .As an analog node you will just about go unoticed for the effort , there is little benefit to tying up even surplus cheap equipment for something like that ,maybe in 5-10 years if the mode catches fire , at this point unless you have an existing base of users scrambling for an analog node ,you will be invisible and lonely .
Sent from my SM-T810 using Tapatalk
