Wondering how encryption works.
Thatsclear
I'm just curious of an example of a encryption code? I mean AES256 for instance, is it just "ABCDF1873487934594DJHSGFD9584857HFKHFJKFHSF8957304" --- but 256 characters and that is what is done? Just some random string of letters precents people from hearing?
thanks
a417
Do you know how encryption in computers works?
Like when something is encryted to be sent and recieved, or are you asking for a really ELI5-type breakdown?
Understanding what you know (or think you know) will help the hive-mind here possibly help you.
This information is found all-over the internet, the only real functional difference with radios is that it is sent over RF...no wires.
You can go into any search engine on any platform and google "how encryption works" and find a very large amount of content out there.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
thanks
Not 256 characters, 256 bits.
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
0-9 and A-F. Such as...
0B561C11C750819B8675E2089E6298B3B614F99C763E33B3F4BAF42887F2C4AB
And of course my example isn't...
a cryptographically strong key that involves 14 rounds of randomization, SHA-512, PBKDF2, HMAC, a 64 byte initial token, a 64 byte dynamic salt, and 1 million iterations
...but I seriously doubt anyone will figure out any key variable I use. :p
GlobalNorth
Fort Misery
Learn quantum encryption. There's a ton of cash to be made in it and you'll single handedly earn an Intelligence Star medal from the IC.
merlin
DN32su
Not too complicated. ALL trunking and DMR is digital weather voice or data. Encryption passes that data through an algorytm that permutes shifts, and obfuscates that digital stream (Cypher text). Now that algorythm uses a "KEY" to both encrypt and restore the original
back to plain text. That "KEY" is internally gennerated from a 'seed'. That seed may be 64 to 256 'bits'.
That means without that correct 'seed', there can be as many as 255^255 possible cobinations, and only one correct one to decypher the data stream.
David628
Colorado
“I'm just curious of an example of a encryption code? I mean AES256 for instance, is it just "ABCDF1873487934594DJHSGFD9584857HFKHFJKFHSF8957304" --- but 256 characters and that is what is done? Just some random string of letters precents people from hearing?
thanks”
Searched google, maybe this?
Forts
Ontario, Canada
As mentioned, AES256 is 256 *binary* bits, whereas DES is 64 and ADP/ARC4 is 40. These translate to a 32 byte, 8 byte and 5 byte hexidecimal key, which is the value that is typically entered into key loading device for the radio.
For example...
AES256 - 8F0284863DB01EB026A7C7599758F06936AC07526820C7463D2BFD8E0B858749
DES - C297B5B086BC0268
ADP - B4499FE923
ladn
Part of the strength of the key is the number of elements (more elements=greater number of possible "answers").
Another part of this is how the key is derived or generated. A key that uses a predictable set of elements, like 000111222333444...EEEFFF would be less secure than a key derived from a true random number generator.
As I recall, the NSA has a subsidiary or affiliate that provides a key generation service based on a true random number generation algorithm. The keys are generated and transmitted securely to subscribers (think three letter government agencies and large state/local law enforcement) electronic key vaults and then loaded into equipment. There's no need for anyone to actually view the key's character string.
jimmy9999
Not really.
A 64-bit key gives 2^64 or 256^8 possible keys.
A 128-bit key gives 2^128 or 256^16 possible keys.
A 256-bit key gives 2^256 or 256^32 possible keys.
RayAir
For example...
ADP - B4499FE923
ADP- ABC123
DES- 0123456789ABCDEF
UAT_978
I bet I know one.. lol xxxABC0000
merlin
DN32su
Not really.
You are right, I stand corrected, still, 2 with 256 places is a lot of combinations.
krokus
Southeastern Michigan
The Security Now podcast has episodes that explain encryption well. They are old episodes, so I would suggest using a search for them. All of the information is applicable to radio traffic that is encrypted, when using a digital radio format, such as P25, DMR, NXDN, etc.
