Wouxun Wouxun Software
tadpole207
Hey All
i am using the wouxun software to program my UV9d Mate. It is very different from Chirp, in that it does not have offsets + or - or the amount of the offset in the same line as the frequency info like Chirp does. Does anyone know how to program offsets using the wouxun software?
thx
n
hill
Middle River, MD
I haven't used this software before, but would guess it's like commercial software.
No offset you have to enter the receive and transmit frequencies. The receive would be the frequency the repeater transmits on and the transmit would the frequency your radio transmits to the repeater on.
Standard offsets would be 600 kHz for 2 meters and 5 MHz for 70 CM. You just need to know the direction of the shift to calculate.
In closing should be too difficult to do, since many hams including me use Part 90 radios on the ham bands and these radios must be programmed this way.
sallen07
Rochester, NY
@tadpole207, @hill is absolutely correct.
I don't have a UV9D-Mate but I just downloaded, installed, and ran the software, which looks just like every other CPS for Chinese radios. :)
You need to put in the RX and TX frequencies. The transmit tone (into the repeater) goes in the "Encoder" column, and the receive tone (from the repeater) if any in the "Decoder" column. Don't forget to set "W/N" to "WIDE" if these are ham frequencies.
