WS-1040 NAC ????
Forts
Mentor
Ontario, Canada
Do you mean NAC? NAS doesn't apply to a scanner. What are you trying to do?
Whiskey3JMC
Resident Numbskull
Simulcastylvania, TE
You're a premium subscriber so you should have access to frequency data search. Enter the frequency (which you neglected to provide) and the NAC in their respective text boxes as illustrated below and see if any results come up.
dave3825
Suffolk County NY
Op is most like referencing this, which fwiw, does show partial encryption.
Polk County​
FrequencyInputLicenseTypeToneAlpha TagDescriptionModeTag
155.550158.850WQFA852RM490 NACPOSOSheriff DispatchP25eLaw Dispatch
Forts
Mentor
Ontario, Canada
As mentioned above, it's noted that encryption is used on this channel.
Whiskey3JMC
Resident Numbskull
If I put in 155.550 all I hear is a buzzing sound The letter e does that mean the freq is encyrpted?
It's listed in the RRDB as partially-encrypted (P25e, lowercase "e" suffix) meaning you should be able to hear some clear transmissions assuming they haven't since switched to full encryption. As previously mentioned you'll need to program sq mode as P25 & program NAC as described here
dave3825
Suffolk County NY
Usually when one hears the buzzing, it means the freq is programmed into the scanner as analog. Are you entering it as P25?
Like others have said, yes, but partially meaning maybe just dispatch is E, or just units are E. At some point, encryption was observed and submitted to our database. If that stands true today, and it's still only partial, you should hear something if programmed correctly.
tvengr
Well Known Member
Baltimore County, MD
Encryption sounds like distorted audio which you cannot understand. If you hear a buzzing sound, you most likely have it programmed as analog. The same frequency is used for both analog and digital. If you don't have the PL tone programmed for the analog frequency, you will also receive the digital signal and hear the buzz.
155.550WQFA852RM490 NACPOSOSheriff DispatchP25eLaw Dispatch
155.550WQFA852RM179.9 PLPOSOSheriff/Police DispatchFMNLaw Dispatch
