WS1040 -Nothing Enabled message
64squares
Hello Folks,
I have a WS 1040 and have downloaded some frequencies from the site using ARC 500. However, when I press 'scan' all that happens is a 'Nothing Enabled' message appears. I've tried the following steps:
5.3 Nothing enabled message:
The PSR500/600 only scans objects that are assigned to a scanlist. If you get the Nothing Enabled message check the following:
- the objects are assigned to at least 1 scanlist - the scanlist is enabled (Global Settings, Scanlist tab). - at least one object has the lockout flag set to off. If the lockout flag is set to On for all objects the scanner will also display the Nothing enabled message
Please, what am I missing? I know it has to be something basic. Is there something I'm possibly missing with the download?
Thank you
Ronaldski
MI DB Admin
Bay City MI
64squares
nothing enabled
Thank you very much for the links!
A lot of good information...sadly, it still doesn't work.
I know I'm missing something...
I've attached a pdf of 2 screenshots from arc500. All the objects have been assigned to scan list 1 and Lock Out is set to off.
I then press scan and of course receive the nothing enabled, I see from the links you provided to press 1, but that still doesn't work. I also tried to upload the frequencies I download to see them, but those don't appear in arc500 - shouldn't I be able to at least see that?
thank you for your time
  • not enabled.pdf
Swipesy
Northern Ohio
Your Configuration looks fine. When your scanner is scanning does the Number 1 show on the screen or do you just see a black dot? If the Number 1 does not appear then ScanList 1 is not enabled. I also assumed you uploaded your configuration to the scanner?
64squares
Hi,
I feel so stupid, but I did get it to finally work. What happened was instead of selecting the download (blue arrow) icon from arc500, I was selecting upload (red arrow)...also, I didn't realize every download erases the previous download.
Thank you for all the help!
lou9155
shamong nj
Hi,
all the newbies using arc500 do the same thing..dont feel bad
WiggyWonka
Ohio
Mine still won't scan, it still has the enabled error, but I got it to stay on one channel. LOL I guess that is better than nothing!
lou9155
shamong nj
Hello Folks,
Thank you
you hit down load FROM scanner instead of upload TO scanner....
