X-ray
rhalld38
Rockford, IL.
I have not flown in several years and I have read past posts about bringing a scanner to the airport but one question I did not see, if I have my scanner in my carry-on bag does TSA run the bag through the x-ray machine or do they search the carry-on? And if it does go through the x-ray with the scanner in the bag would the x-ray hurt the scanner? Like I said I have not flown in several years and this will be the first time I will fly with a scanner.
K8TEK
Banned
Ohio
X-raying is fine for every other electrical device, but it will kill the scanner. I would be more worried about a laptop then a scanner and I have yet to hear of an x-ray killing a laptop.
KE7JFF
TSA actually when they took over phased out any airports in the US that used x-ray machines (there was like 3 left) and instead uses CTX machines which are tottally different.
sigint1
Was: joking
They have not phased out x-ray machines - CTX machines are a combination of a CT scanner and X-ray and are used to screen checked baggage - X-ray machines are used at the checkpoint for screening carry-on items. Here at Reno international Airport they are the same X-ray machines that we installed about 4 years before 9/11. CTX machines can damage camera film so if you are using film (like 35 mm camera film) then you should put it in your carry-on bags - the regular x-ray will not damage most film.
I have flown several times with my hand held scanner and TSA hasn't even given it a second look - only thing they ever looked at was my magnetic base GPS antenna.
shaft
Wentzville, Mo
I tend to take my 396 and the Vx7-R with me when I fly and they travel in the middle compartment of my laptop backpack, which I carry-on. Only once this past year did they take a second look, they were more concerned with the various cables I had in the same compartment then they were with the radio and scanner.
N
N_Jay
Guest
Put real film in a lead bag or ask for hand inspection.
If you are still using film, you are probably picky enough that you don't want ANY degradation from even low level x-rays.
N
N_Jay
Guest
. . CTX machines are a combination of a CT scanner and X-ray and are used to screen checked baggage . ..
All true, except for leaving the impression that a CT is NOT an X-ray.
It is an X-ray, just computer aided presentation.
sigint1
Was: joking
I don't think I left that impression - if I did I apologize, but I didn't say that it was NOT an x-ray - If you read my post again I said it was a combination of a CT scanner AND X-ray - I was just trying to put it in simple terms that most people had a chance of understanding. The main point I was trying to make was that the regular x-ray machines have NOT been phased out and that the x-ray machines used to screen carry on items at the screening checkpoints and the CTX X-ray machine used to screen checked or hold baggage are two different types of machines employing two different technologies.
PS: It has aslo dawned on me that I have strayed into an area that is most likely off topic for this group - I apologize for straying afield and this will be my last post concerning this topic - joe
Lowa2
Canada
For baggage that you check at the ticket counter, everything goes though a CT machine. Your carry on baggage goes through a conventional xray machine. I know, I work on them.
KE7JFF
I'm talking the OLD school X-ray machines; the ones that were basically giant dental x-ray machines that were put in place after DB Cooper. Those ones are long gone; but some very small airports post-9/11 but pre-TSA had them still. CTX scanners are what you said, CT + X-ray but it uses the x-ray at a much lower dose because it does image processing more efficiently.
CTX scanners actually don't harm film up to ISO 3200, but you can request a hand inspection of film if you want to under TSA (and CATSA) regulations if you chose too.
dagwag77
Boston Metro Area
I've taken motorola radios though TSA security all the time. Never hurt XTS2500 or HT1250s....so I think a scanner will be fine. They've never even seem to care or ask any questions...
N
N_Jay
Guest
Not to nit-pic, but you said "it was a combination of a CT scanner AND X-ray". My point is a CT IS an X-ray. So it is NOT two technologies, it is one technology, X-Rays, that are computer enhanced.
smason
Alberta Canada, Eh!
Please elaborate, how exactly would it kill the scanner?
