XG-100M Questions
LLOYD0703
Plantation, Florida
Make sure you are programming using the Unity Product Management tab. I use either Bluetooth or USB connected to the control head.
When you upgrade to the CH-100 things operate a little differently. The control head can store multiple profiles and let you switch between them on the fly.
Got it perfect. So I would basically program it just like I did using the Bluetooth for my 100p?
LLOYD0703
Plantation, Florida
Yep! Same process.
Ok, so.. I open the unity product management, initialize the Bluetooth and the radio appears but I can't get the personality to appear in the bottom screen so I can send it to the radio. I have tried a bunch of different steps but don't seem to be able to remember that part. Thank you again for the help.
BMDaug
I am licensed…
Central Colorado, USA
You need to switch the radio type to XG-100M/CH100. RPM sees the CH721 and CH100 as different radio types. You will have a few different options to play with too.
-B
LLOYD0703
Plantation, Florida
Thank you all for all your help, it definitely made life simpler and the programming of my radio a breeze. My xg-100m with a CH 100 head is now fully programmed and operational and I couldn't have done it without all of you. This group Mega rocks. Thank you so much
prcguy
If you couldn't get the CH100 running I was going to offer you $75 cash for it....
nikronzo
4.X SloppyCast
The entire mission plan is different for a CH100 versus a CH721, in RPM or RPM2 you will see that there are 2 different mission plan types that can be loaded, 100M w/721 & 100M w/100, you need to reprogram the brick itself for a CH100 control head.
LLOYD0703
Plantation, Florida
Good evening. All done. Thank you. That is what I did earlier. All bands tested and works perfectly.
