XG-100P Roaming issue
AES-256-Encryption
"Be the change we need"
I have an XG-100P, and for some reason, it absolutely will not stay on the system I want. I’m using Enhanced CC. I have two systems, both at roughly the same distance, but no matter what I do, it won’t stay on System 1.
If I go outside, it switches to System 2. If I drive toward System 1, it might briefly switch but ultimately sticks to System 2. Both systems are set to Enhanced CC. I’ve tried ignoring sites, but then it just locks onto another site of System 2.
System 1 has 30 sites, so I can’t add many as “Never” Does anyone have any ideas on how to fix this?
Los Angeles Regional Interoperable Communications System (LA-RICS) Trunking System, Los Angeles County, California System 1
California Radio Interoperable System (CRIS) Trunking System, Various, California System 2
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Maybe your ID isn't allowed on "System 1".
nikronzo
4.X SloppyCast
I can't, but the reason the 100P is less than 500 is because its now 16 years old and almost everyone I touch has some level of failures. The biggest being bootscreen lockup and no recovery via IPL or even worse, the pigtail RF connector going dead rendering the portable also as useless. Meanwhile people are still trying to get $2k for APX7000s -_-
prcguy
There are a few bad 100Ps out there but not that many. A friend got about 170 of them surplus and some are worn out from use with wobbly knobs, scratched screens and the like but I don't remember any having a boot up problem. Not to get too far off topic but I have APXs and in most cases prefer Harris. In fact today I just swapped the APX8500 in my truck back to an XG-100M because the Harris does things the APX cannot and never will. Plus if its stolen its cheap and I won't cry like getting an overpriced APX stolen.
So is it ok to help the OP try to figure out how to get his mission plans working?
KC8ONR
bridgeport
The hate on harris is crazy.....
Take the M7300 same age as XTL stuff , works great even on the phase 2 systems of today with the right feature set. Try that with xtl or xts.
Anyway , to the OP , you may wanna try Dynamic proscan you have more control over the sites the radio listens to. Just my .02 cents 😀
snoopyII
On the other side of the tracks
Don't use ECC, use Fixed ProScan instead. You'll have better control on where the radio roams because you define which sites its are in the system scan list.
I've never used Dynamic ProScan myself, because I'm not sure if the radio built system scan list overrides user defined system scan list or how they interact with each other.
AES-256-Encryption
would you create like 5 or 6 different systems and name them the site names, then select them under dynamic and assign them all the group set?
snoopyII
Create as many systems as you wish, assign them to the "systems being scanned" remember they all must match up or wonky things happen when the radio wants to roam. Define a priority system if you wish, if you do so, the radio will always favor that system, so it should be the one that most often has the TG's you wish to listen to.
AES-256-Encryption
ill look into it, my ECC works great if you block all the sites of the other site. I have the one site in, then I block all the surrounding sites of other systems and it works fine.
snoopyII
ECC can work well on smaller systems, but the preferred system table is limited to 36 (?) entries, so it has a tendency to not work well for larger or statewide systems, or area where there are multiple DTR's in the same area.
