XG-100P Roaming issue
AES-256-Encryption
"Be the change we need"
Mexico city
ECC can work well on smaller systems, but the preferred system table is limited to 36 (?) entries, so it has a tendency to not work well for larger or statewide systems, or area where there are multiple DTR's in the same area.
I think 36 yes, my only thing would be having 60 systems then trying to find a channel would take ages? maybe not ill tinker with it when im off work.
northstarfire0693
North Carolina
I use fixed proscan on mine. Works great and if I want to go to another system. I just switch it to the system I want. Doesn't roam or change sites unless I tell it to
merlin
DN32su
I can't, but the reason the 100P is less than 500 is because its now 16 years old and almost everyone I touch has some level of failures. The biggest being bootscreen lockup and no recovery via IPL or even worse, the pigtail RF connector going dead rendering the portable also as useless. Meanwhile people are still trying to get $2k for APX7000s -_-
Some radios do suffer cold solder connections, they can be fixed but wow, the tiny connections.
natedawg1604
Colorado
How are subscriber radios using Enhanced CC prevented from randomly roaming onto other systems, outside of the system ID specific in WA Network?
AES-256-Encryption
Mexico city
notice how all motorola systems use BEE00? When a harris goes into band hunt it looks for wacns and control channels. harris systems have special wacns instead of the same old one. I found if you goto scan settings and turn off band hunt interval from 10, to 0, it never roams off network.
