XG-75P Problem
swcscott
ohio
Somehow on My XG-75P I accidently by a series of unknown keystrokes got into what appears to be the FCC Menu option and now I don't know how to get out of it. I am only able to see the 2 choices below. Only the menu key works and my only 2 choices are below and I am unable to get into program mode. Anyone know how I can get out of here?
Ready
PBAPP R13.05
M: BAPP
Sel to Load
Thanks,
Scott
jess_sherman
Go to M:BAPP, then it'll ask you to M:ECP and confirm yes and it should boot you back into your regular radio mode, though that just what my memory tells me and my memory ain't the best.
swcscott
ohio
That fixed it. I need to write that in my notes so I don't forget it. Really appreciate the help.
Scott
ElroyJetson
When I get into the FCC menu I exit it by moving the rotary selector to another position. That causes it to exit the FCC menu.
I use the FCC menu feature to access the signal strength and trunking channel data screen so I can identify channel-specific (repeater specific) quality issues. And map site coverage.
MikeNike42
Iowa
How do you get to the FCC menu?
JackRimawi
Dose any know how to get the XG-75Pe into programming mode because RN my screen says needs program.
JackRimawi
It's blank and needs a personality loaded. Connect to RPM or RPM2 and load up a valid personality.
This is the error I get trying to programming the radio and it's power on the programming cable is connected I selected com 5
JackRimawi
It's telling it can't initialize the radio and make sure it's in programming mode but the radio is on programming cable connected and I have selected to com 5 and I don't what else to do
Forts
Ontario, Canada
Could be improper port selected, connector is not properly attached to the radio, issue with the connector itself (occasionally they need a little cleaning)... Etc etc.
merlin
DN32su
Pressing the MON/CLR button should back out of FCC menu.
merlin
DN32su
Is there anybody that knows how to get my xg75p...back into the program mode...Screen is blank ?
Connect the programming cable and power up should display "program"
If not hold the PTT button and power up, Display should be black.
