XG-75p screen
LowderK
LEO / Paramedic
Western Oklahoma
I have a working XG-75Pe but the screen is DIM can they be easily fixed or replaced.?
mikegilbert
MHz so good
Los Angeles
I haven't done one myself (yet), but it seems pretty simple to replace. I just would reuse the screws and gaskets, in spite of what this says.
The part is available here: New London Technology Online Store
Not to hijack, but I've got an XG-75pe with a loose (but functional) channel knob. I'm familiar with Motorola gear, but have never worked on anything Harris yet. Have you done any knob repairs on them?
Thanks!
merlin
DN32su
Dim display, presuming you have brighnes and contrast set in menu, note:
This is not always the display modue. You have series resistors in the power rail that can degrade, so before condeming the module, check that it is getting the proper voltage per service manual.
Thanks!
If the rotary knob is loose, check the spanner nut that holds it to the frame, they can work loose over time.
That not the case, the switch itself, may be failing and needs to be replaced.
merlin
DN32su
If you change the module, just be very careful of the ribbon zif connector, they break very easy.
