XG100P says "No key" despite loading AES KEY via Harris key loader software.
Mogley
Created a key between an apx with AES and loaded the same key into my Harris XG100P with the Harris software. When I test it with the Motorola, the Harris says "No key" despite the key icon on the screen.
Do keys get wiped after a Bluetooth program/Mission plan reactivation?
Any ideas?
nikronzo
No
Check your KID, KeyAdmin can get confusing with hex vs dec. Likely a mismatch their and between your Key Name list reference and its respective P25 system.
Mogley
For example, my Motorola radio has the key ID of 1300. Is that the same thing I put in the Harris?
Forts
Ontario, Canada
Keyadmin wants all KIDs in decimal, and when you are seeing a KID like 1300... that could be hex or decimal. If 1300 isn't working, give 4864 a try (1300h = 4864d)
Mogley
No
I was unaware of that, Im used to the keyID/CKRid being what a KVL 4000 displays or what's in a codeplug of an apx. Il give that a shot.
Does that also reflect the keyID mentioned on the RPM software too? (AKA decimal for both)?
nikronzo
You can change KeyAdmin settings to reflect KID in HEX to match MSi format.
Mogley
Not know that I will take a look thank you
Mogley
Still didn't work, no idea why it's not working.
Mogley
Can confirm this was the problem. I had no idea this was a thing. It works flawlessly.
