Xl-200P Non-affiliated scanning
KR4DFT
I am having my tail handed to me trying to configure my radio to do Non-affiliated scanning. I have added the p25 table and everything I found in a video for setting up a XG-100, but I am unable to receive anything on any p25 phase 1 or 2 configuration. Not sure where I have messed up and so far YouTube has been no help to set up the XL-200p for nas.
K2NEC
39A
Channel ID is system specific so if you copied off a video, chances are it won't work
Without going into specifics, its hard to help you and tell you what you did wrong
KR4DFT
Give me a few and I will grab some screenshots if you know what to look for. I will have to check but I'm sure I put them in as it shows in this table.
KR4DFT
Here's what I have in RPM for my IDEN table
AES-256-Encryption
Based in the US, always nationwide
ØAES
One thing im not 100% sure on it, but have been told is make sure you check data inhibit. If not it will send CC data. Same with obviously never for affiliation.
Echo4Thirty
Colorado Springs, CO
100%. I would also uncheck "Calls" on each TG. From the RPM Help:
Calls
This control enables or disables individual calls while on this group.
Checked: The radio will transmit or receive individual calls while on this group.
Unchecked: The radio will not receive or transmit individual calls while on this group.
Default: Enabled
KR4DFT
I have that checked and still doesn't get anything.
Calls
Default: Enabled
Calls is unchecked.
io401
The IDEN table can be received over the air, so it's okay to enter placeholder values, the radio will automatically correct them once it locks onto a valid control channel. However, it's important to ensure the Site ID, RFSS ID, and NAC are accurate. If you're not completely certain of those values, use Enhanced CC Mode to help lock onto a control channel.
AES-256-Encryption
ØAES
Yes, he was missing those.
AES-256-Encryption
ØAES
The harris didnt download them OTA? I have noticed that is one thing the Harris radios do that the Motos do not.
Well ensure that your NAC RFSS and site are set. My XG will find the system band plan using a default one.
Echo4Thirty
Yes, i do set all of that. Mine downloaded the bandplan OTA on a VHF system I NAS. I fat fingered it on both my 200P and APX and the 200P corrected it while the APX was mute.
Once I ran unitrunker on the site and figured out what I entered wrong (had wrong base freq) then the APX was happy also.
KR4DFT
Thanks to all that have commented on this,. I'm just settling in from being out of town, and I'm working on trying out the fixes now.
ElroyJetson
XL-200P, so using RPM2.
Set RF power to RF safe. Lowest possible.
In P25 systems data pages,
Set power to low, auto registration to never. Unit registration to never.
Advanced P25 user login set to no login suppported IF relevant. Leave alone if not.
Misc options, uncheck all except TDMA capable if it's a Phase II system.
In sets-p25 groups, uncheck TX, uncheck Calls. For Every group.
Leave system NAC to default/0. Don't need it for RX.
All references to site ID need to carry the correct site number. It's usually the same for all entries of site ID numbers, for any given system.
I haven't found a relevant data inhibit checkbox for P25 system data. Where are you seeing that?
AES-256-Encryption
ØAES
