XPR 6350 Firmware
rcoughlin
Morrisville PA
Hello,
I just took over the radios here at my building, I have 43 XPR6350's I have a purchased copy of CPS and after importing all my radios and seeing what is programmed in. One of the main concerns I have is the Firmware.
I have approx 1/2 at R01.06.10 and the remaining 1/2 at R01.06.20
I have my account at MOL and have downloaded the current firmware version supplied by Mototrbo,
However I can not "import firmware" it says no valid package.
How can I correct this?
I am lost!
JRayfield
Springfield, MO
The firmware has be 'installed' on your computer. Did you 'execute' the .exe file that you downloaded?
John Rayfield, Jr. CETma
W0PM
JRayfield
Springfield, MO
There are only two reasons, that I've seen, for what you're seeing:
1. The CPS is too old for the firmware version that you're trying to install.
Make sure that your CPS is version 10.7. That is the absolute newest and is needed for the absolute newest firmware.
2. You downloaded/installed firmware for a model of radio that is different from your radio.
The file that you need or an XPR6350 is "MOTOTRBO_R011213_130201_Portable.exe".
W0PM
Rayfield Communications
rcoughlin
Morrisville PA
I have the most current version of cps. I may have downloaded the wrong file from mol. Let me search for that file on Monday and see what turns up.
JRayfield
Springfield, MO
Make sure that you didn't download the file for the XPR3000, XPR5000, XPR7000 series of radios. Those are the newer series of radios and use completely different firmware (but the same CPS).
W0PM
rcoughlin
Morrisville PA
Yes, I downloaded the correct file. Installed it. Launched CPS, when into RM > Manage Firmware > Import Firmware.....No valid packages exist.
Am I doing something wrong.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
The firmware is already installed so you don't need to import it.
Just select Device/Update in the CPS.
rcoughlin
Morrisville PA
Should be the current one, just received it last week. From my dealer. It's on my work computer so I will have to check tomorrow morning. Any thoughts to try in the meantime?
JRayfield
Springfield, MO
You're going into the Remote Management section. That's not correct for what you're trying to do.
From the Menu at the top of the screen, select Device and then Update.
W0PM
rcoughlin
Morrisville PA
John,
See my post above. I have tried that. It still fails on the update, no valid package. Once I get to my office computer I will post screen shots and give you the version I have of CPS.
rcoughlin
Morrisville PA
Here is my version of CPS, and when I attach a radio, read the code plug, and attempt to update this is what I get.
JRayfield
Springfield, MO
You do not have the most current version of CPS. The most current version is 10.7.
rcoughlin
Morrisville PA
Well then, I was led to believe this was the latest version. How to I update CPS, purchase the new release?
**Update**
On the phone with MOT....
Customer Service see's the 10.5 is the most current version
They are talking to tech support to figure out how to get me the current version...Since I can't download it from MOL.....
JRayfield
Springfield, MO
I have no idea why they can't see 10.7 as the newest. I just logged into MOL and it's there, plain as day.
When did you purchase your software license from Motorola?
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Looks like he got it from his dealer.
