XPR 6550 Codeplug Question
RR00212342
We are trying to replace an XPR6550 radio used in a small business. We have registered with Motoroloa and have CPS16.0 Build 828.
I connected the old radio and was able to "read" the code into CPS witrhout any error messages. However when I looked at the code (expert or basic) I don't think it fully loaded the programming since there is no reference to the three main frequencies we use or the alisases for the channels that are programmed into the radio.
Also, when transferred the codeplug to the new radio (again, no error messages) the programming is not there.
Is there a trick to getting the full codeplug to upload?
K2NEC
5F6
Are you using Connect Plus by chance?
UAT_978
Second this. All of the Connect Plus programming resides in the option board so reading the main radio will just have basic data and channels that hand off to the option board software.
That said, even if you could get the programming data out, the other radio will need to have its ESN put in the database and issued a unique ID. Connect Plus systems authenticate (for lack of a better word) the Radio ID against its serial number to prevent clones.
