XPR 6550 for listening
carterbkk
Will a xpr 6550 work for my needs to monitor my local agencies UCSO and PD and fire I’m not going to purchase a scanner I previously had the sds200 had to sell it due to financial reasons and not in the position to purchase it or any other one. So I’m looking for someone that’s knowledgeable on this subject to answer if the 6550 vhf will work to monitor my local frequency’s.
My zip is 71730 El dorado Arkansas.
Thank you!
W4EHS
Palm Bay, FL
Regarding your question about monitoring local Sheriff's Office (SO) and Police Department (PD) radio traffic using unregistered two-way radios, the answer is generally no. These radios are typically registered to a specific system, which means that unregistered devices, such as your 878, won't be able to pick up the traffic.
I attempted to monitor with my own 878 and observed that while it indicated someone was transmitting (keying the radio), I couldn't hear any actual traffic. Conversely, my SDS100 scanner was able to receive the communications clearly.
Based on this experience, it appears that you cannot use a two-way radio to listen in on these communications if the radio is not registered with the system. This is likely due to the system's design to secure communication channels for authorized users only.
carterbkk
What’s the cheapest option I could use that would work.
K9KLC
Southwest, IL
Are you sure the SO wasn't P-25? I guarantee if the SO was DMR or analog if you were in the right band the 878 or 578 would receive it if the SDS scanner did. I do it here for DMR stuff all the time on my 578.
canthonysmith
Arkansas
The SO has a talkgroup on the AWIN system. It is only used as a backup and for prisoner transports out of the county. Other than that, they are full time DMR on their 9 site IP site connect system.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
The 878 wont pass audio because the system is using using RAS. RAS is variable that you create when programming, that has to be selected in each channel you are using RAS.
It appears the system is conventional. If it was not running RAS, using a Motorola DMR radio, properly programmed with CC, TS and TG for each frequency, would work just fine, and as long as the channels are configured to be receive only, your radio would not transmit. Your 879 would also be able to receive the system.
It is not a Connent Plus/Capacity Max/Tier 3 trunking system. The radio doesn't need to register or affiliate to receive and pass audio.
The ONLY reason you can't monitor(unless it's using encryption) is because RAS has been enabled. Proper DMR compliant subscribers will not unmute because of how RAS hashes the headers of the packets.
There may be some cheap Chinese radios that will unmute RAS enabled systems, but I don't have specific knowledge of which radios, if any, can do that. Scanners will unmute though.
carterbkk
So will the xpr6550 work or not
