K
kk4mei
Guest
After 2 days of trying I finally was successful in programing my XPR7550 OTA with a blue tooth dongle.
I brought a bluetooth dongle from bestbuy for 15.00 (Rockfish Micro Bluetooth USB Adapter)
Install drivers
Be sure to check the box marked PAN (personal area network) when asked on mine that was the only box I checked as I will only use this for my radio.
(Restart Computer must do)
Important Windows 8 must be ran as administrator
Steps
1. Put radio Bluetooth into find me mode
Menu/ Bluetooth/ Find me
2. right click on Bluetooth icon on computer then click add a Bluetooth device
3.Double click motorola device when found
4.radio will send some numbers to computer asking if they match device click yes
5.Accept on the radio
Your radio is now paired but won't connect
1.Go to Desktop/ Control panel/ View devices and printers/
2.right click motorola/ properties
3.click the Services tap and make sure to check the
Personal Area Network Access Point (NAP)
Close screen
4. right click bluetooth icon in toolbar
5. Select join personal area network
6. right click Motorola
7. select using access point
Now open your CPS select bluetooth button (Top Right) and read radio.
note: windows 8 does not support the Bluetooth feature Allow A Device To Connect so you will always have to use the computer to connect to your radio. On my windows XP computer the radio can connect to the computer no problem.
Install drivers
Steps
Close screen
