XPR 7550 MDC Decode
radio259
Pittsburgh PA
Where in the software is it to check to decode MDC1200?? Not doing alias list as most of our guys know each others MDC.
TY
ElevatorsAndRadios
yarewesog
SoCal
First, you need to make sure you have a properly configured MDC system. You can find the areas to set up MDC systems in the tree menu. Then, in each conventional analog personality, you should be able to choose a signaling protocol for both transmitting and receive. For MDC decode, assign the desired system to a personality under the receive section. If you want to send out MDC when you transmit as well, make sure to also assign that system to the personality under the transmit section. Please note that if you only assign an MDC system under the receive section, you will only decode MDC and not transmit it *UNLESS* you engage talk around.
This works for my XPR4550. If someone else sees something I am missing, please speak up :)
