SDRTrunk missing calls, stream ok
kb8zxe
Wakefield, MI
I am currently feeding two calls nodes (two sites on MPSCS) and a conventional feed. When I try to run node 5965 and 6012 in addition to the conventional feed on a single pc the calls platform missing a lot of transmissions. If I monitor the conventional feed it does not miss any of the transmissions but when I monitor via playlist it is very hit and miss. Transmissions that are getting missed by calls do get recorded on the pc. I do not think it is a dupe detection issue by broadcastify. I have no errors in the log file.
If I disable either site and only monitor one control channel the missed calls clear up. If I keep both sites enabled and remove the streaming to calls on one of them the missed calls remain. I believe that I have everything set up correctly with the two sites, two playlists. two alias lists etc... I have two alias lists with each list tied to it's own node number. Both alias lists do have the conventional feed enabled though. I guess my question is should the conventional feed be enabled in both alias lists? I would like the conventional feed to monitor both sites.
Currently I am running node 5965 and the conventional feed on a pc and node 6012 on a pi. It is working flawlessly. I have read through so many threads and I have not found a solution yet. I am fine keeping my setup as it is but if I can get the conventional feed to monitor both sites I would be happy.
I hope that I have explained things well enough and would appreciate any advice.
Bob
EW1407
Check if calls are getting rejected during ingest due to time skew?
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
1. How many SDR devices, and what are their types (RTL-SDR dongle, Airspy / Airspy Mini / SDRplay / RFOne) ?
2. When the two trunked sites and the conventional are all actively being monitored, what is the CPU / Memory free ?
3. Do you ever take a look at the black CLI screen that starts when SDRTrunk starts? Important info about issues may be seen there
4. And as mentioned, check the skew on your node(s) to see if you are way off (you should have some time update app on the device)
Mike
