xpr 7550e frequency range
oddbanana
I just picked a used motorola xpr7550e,got cps2.0, got a program cable, tried creating a channel on frequency 462.5625mhz but I keep getting a "frequency out of range" error message and it reverts back to136.067000mhz, am I just missing something simple, do i need special entitlement? any help is much appreciated, thanks.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
On the back of the radio under the battery there should be a sticker that has a model number something like: AAH56JRDN9RA1AN. The 'J' after the 6 is the band split indicator. You need to find an XPR7550 that has a 'R' after the 6 in the model number. The R tells you it is a 403-520MHz UHF radio.
nokones
Sun City West, AZ
The "R" model XPR7550e operating range is 403-512 MHz.
KE4ZNR
Radio Guru
Pretty sure some of you are missing this important detail from his post....I am also pretty sure Moto does not make a dual band XPR7550...so it should be obvious why he can't program GMRS or any other UHF freq into that radio.
nokones
Sun City West, AZ
They are not Part 95 approved or Type-Accepted radios.
However, Part 95 does allow the " USE" of LMR type-accepted radios, on Part 95 freqs providing that they are used/operated in accordance with the respective Part 95 subparts in the radio service where that radio is being used.
In this case of operating on 462.5625 MHz with a GMRS license, the station operator "using" his XPR7550e radio, is allow up to 5 watts ERP, and must meet the other requirements insofar of emissions, frequency accuracy, etc. as required by those rules in subpart E. In other words, a LMR stations cannot exceed the power, accuracy, and emissions requirements as Part 95 Subpart E Type-Accepted radio must adhere to.
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Can you cite that somewhere? Or is that just how you interpret the rules? It would seem odd to me that companies would go to the expense of having both part 90 and 95 certs when 90 is all they need.
On second thought, the OP has a VHF so I'm closing this as I know you can't cite where a part 95 type acceptance isn't needed.
