XPR Programming question
Rudy3145
New York
When my XPR alerts for a selective call from tones, it alerts but doesn't allow audio (dispatcher message) through. Anyone know what setting I'm missing?
a417
Change "Call Alert" to "Call Alert w/ Voice" under the Quik-Call II System Call Type. ( I am assuming you are using two-tone signalling, yes?)
Rudy3145
New York
I think I tried that, but I'll try again. Yes, two-tone QCII alerting. It opens the radio ok, but mutes the dispatch audio
a417
Can virtually guarantee that's it. That's on page 548 of my PDF, ymmv.
Rudy3145
New York
Tried them all. Still wont allow voice through. This is strange
K2NEC
5F6
Send a screenshot of your signalling page
a417
Check your signalling squelch as well. Lets see that screenshot.
K2NEC
5F6
Set auto reset timer to Auto w/o carrier override
a417
If the dispatcher talks w/o tones, do you hear it? Might be your RX mute/unmuting rules.
Rudy3145
New York
I played with the AND/OR. If I leave it on OR, it allows 24/7 audio on that channel which I don't want. So its on AND and set to STD Unmute, Mute
Rudy3145
New York
If the dispatcher talks, I don't hear it. I can see the activity bars, but it will alert when tones are sent - then no voice. Call ends and thats it. But other times, no -I cant hear dispatcher on paging channel
Tech21
Did you figure this out? If not, can you PM me your codeplug?
Rudy3145
New York
Everything was programmed correctly. For testing, I was setting off the tones with my HT1250 to see if the XPR would alert properly. I was alerting, but would time out as soon as tones were done, not allowing voice to come through. But when the tones come from the actual dispatcher, it works ok, alert & voice. So, the issue was only occurring with my HT1250, which is odd - and drove me nuts for hours. But it works fine with Dispatch, so I'm a happy camper.
a417
Ok, so that was an issue with the sel cal settings on the HT1250, got it.
