XPR XPR5550e is not being recognized by PC
jake_Braker
C/O 2Ø21
Somewhere in NC
My XPR5550e is not being recognized by my PC. My portables read/write fine but my mobile read/write once, then after the power cycled the laptop wouldn't recognize it.
I have reinstalled drivers, checked my device manager settings and firewalls settings but no change.
Error Code: 1687
TIA!
K2NEC
NA
What kind of cable are you using? Is it a front or rear programming cable?
APX8000
Sarcastic Member
AES-256 secured
The fact that is actually wrote once makes me rule out your cable. Uninstall and reinstall CPS as an Administrator. You can also try upgrading the driver and pointing to C:\Program Files (x86)\Motorola\MOTOTRBO Drivers\RNDIS.
tweiss3
Is it time for Coffee?
Ohio
Reboot the computer? I've had connection issues randomly pop up that a reboot resolved.
jake_Braker
C/O 2Ø21
Somewhere in NC
One thing I can note, the cable is seen by the radio, but not by the laptop I use for programming or my personal laptop.
tweiss3
Ohio
Have you tried swapping USB ports? Try a USB3.0 port and a USB2.0 port.
Also, under device manager, are there any unidentified devices?
tweiss3
Ohio
Are you plugged into the network via cat5/6? Try unplugging it and see if that fixes it.
Have you tried a recover on the radio? Off chance the radio got corrupted on the last program.
I've never had a problem with the bluemax49er cables, but there is a chance the cable went bad. Open a support ticket with him directly, he was always quick to respond.
jake_Braker
C/O 2Ø21
Somewhere in NC
Okay, I got a good connection now. Trying to write my new CP to the radio and it say's the CP is corrupt. Code 1089.
APX8000
Sarcastic Member
AES-256 secured
1). I've had luck "force writing" that code one time. Just kept hitting write until it finally took about the 10th time.
2). Can you read the radio ?
3). May want to try writing a new "blank" codeplug
jake_Braker
C/O 2Ø21
Somewhere in NC
1) No luck here
2) Yes
3) Worked with no issue.
I guess that's my only hope is to just build another one from scratch. Which is what I was hoping to avoid doing.
KA0KDW
Polk County, Mo
I occasionally have that issue with my 7550e. Usually while it’s plugged in I have to go to device manger and uninstall device. Then unplug from computer then unplug radio and finally turn radio off. Then plug into computer then plug radio in. Then turn radio back on it it works fine.
