XPR5550e monitor?
wa8pyr
Staff member
Lead Database Admin
Ohio
OK. That standard mic clip is the HUB Hang Up Box. When the mic is attached to the HUB, it activates the PL. When its off the HUB, it de activates the PL. No sensors or extra buttons needed. Its a spring clip mounted to the inside of the clip and when it contacts the HUB it completes the circuit.
The old-style HUB was a little metal box with a slide switch on it; had to be wired to the control head. I'll just bet I still have one or two in a box out in the garage.
If I recall correctly the newer radios work through vehicle ground; if the mic hook isn't properly grounded (and the circuit completed through the hang-up button on the back of the mic), the HUB function won't work right. if you have trouble, try grounding the mic hook and see what happens.
By the way, it also works for scanning on some radios; when the mic is in the hook the radio scans, when it's out of the hook scan stops and the radio goes to the selected channel.
I haven't used HUB programming since we got away from the days of co-channel interference (neighboring agencies being on the same frequency); PL is always on for anything I program these days.s-l1600.jpg
clbsquared
Isle of Wight County
I haven't used HUB programming since we got away from the days of co-channel interference (neighboring agencies being on the same frequency); PL is always on for anything I program these days.View attachment 98703
The XPR series mics ( as well as a few others) do not require the clip to be grounded. The clip button on the back of the mic is actually two pieces isolated from each other and the hang up clip completes the loop. No ground wire necessary.
wa8pyr
Staff member
Lead Database Admin
Ohio
OK, solves that problem...
N4KVE
PALM BEACH, FLORIDA
Years ago when I didn’t use a hang up box, I’d open the mike, & short the circuit so the squelch would always be on. Now, newer radios can be programmed to work the way I want. But I still have some Kenwoods where the modification was needed.
KK6ZNS
K1MES
Brisbane, CA
Hi All, I spoke with a rep from Motorola Solutions. He confirmed that their mobile products (eg the XPR5550e in question) do not have Monitor toggle, where as all their portable (handheld) units do. He understood why I needed it. His suggestion was for me to fill out a feature request form, which I did. I asked if I may share this form (link) with relevant parties and he OK'd it. So, here you go:
Feature Enhancement Request Form
clbsquared
[/QUOTE
Your only option is to configure your radio as I suggested. When the mic is on the clip, monitor is off. When the mic is off the clip, monitor is on. No sound comes out of the mic, by the way. It's just acting like a.......well........toggle.
KK6ZNS
K1MES
Brisbane, CA
Hi CLBSquared, can you elaborate on how you can toggle monitor but with no sound coming from the speaker? My only experience with monitor toggles is that when on the speaker blasts static (until someone transmits, of course), and hence why one typically toggles it vs leaving it on. Thank you,
clbsquared
You’re wanting to turn the squelch down so you can hear distant tx aren’t you? I think I understand what you’re wanting to do now. When you configure the radio as I was discussing, you’re not opening the squelch. You’re taking the PL tone away and putting the channel in CSQ mode so you hear everything broadcast on that frequency. Which is why they don’t offer a “monitor” on mobiles. Kinda difficult to drive down the road with one finger holding down a button on a mobile and driving at the same time.
KK6ZNS
K1MES
Brisbane, CA
You're correct. I want to listen to weak signals that I can hear just fine with monitor on, and sometimes are chopped off with squelch.
