Thanks very much! I managed to get a copy of the R02.09 firmware thanks to another member of this forum. So you're saying that I can't go from R02.30.01 directly to R02.09 using CPS v16 with the 25 KHz wideband entitlement? What do you mean by "You will need to walk this forward to R02.06.nnnn"? Would I have to upgrade to R02.04, R02.05, R02.06, and then R02.09?
If I manage to upgrade to R02.09, my thought was that I would stick with that so I can continue using CPS v16 and not have to switch to using CPS 2.0 unless I have to for some reason. I've read a lot of negative "reviews" of CPS 2.0, but as
@exkalibur said, there's nothing wrong with it functionality-wise, so perhaps I should just take your suggestion and eventually switch over to it.
I see that "SUM entitlement" stands for "Software Update Management EID". I don't have that. I guess what you're saying is, even without it, I can follow your suggested process.
I really appreciate all your advice, guys! I'm clearly a novice when it comes to navigating the Motorola Solutions website, and using their CPS software to update firmware and create/modify codeplugs.
