XPR7550
J
jerryray
Guest
Has anyone come up with an external antenna adapter for this radio?
TIA
N1XDS
ÆS Ø
TIA
Only Motorola has both retail for $200 each it's not worth it unless you plan on using the external antenna forever.
MTS2000des
5B2_BEE00 Czar
and the service part that is the antenna adapter you speak of is intended for alignment/service only. the little connector on the rear underneath the "XPR7550" plate is not strong enough to survive being used regularly.
At the end of the day, if you need a mobile, buy a mobile.
