XPR8400 Ethernet Not working
pkuntzy
Hello community. I have an XPR 8400 running 2.3 FW. I can not connect to the thing with an ethernet connection. I cannot ping the ip set in CPS, nor can I even see it in my ARP table. That said, the lights on the unit, and my network switch are active and showing activity. Any suggestions where i go from here?
RFI-EMI-GUY
Are you trying to run dual mode analog/DMR/IPSC? It won't do that.
pkuntzy
I'm not sure I follow. To answer your question, I'm running two digital slots. No analog. No ip site connect. I'm trying to connect to the controller with cps via Ethernet. Later on I'd like to use trbonet. I can't ping the controllers ip I set when connect via usb
