XPR8400 Lost ethernet connection
jabrams
NYC
It appears that my Motorola XPR8400 which was connected to DMR-MARC lost its ethernet connection. I cannot ping the repeater from my computer to my router. I also noticed that this model does not have ethernet lights on the connector like a computer would have. I checked the CPS and my static IP is correct. When I also look at my router's configuration, it does not show the repeater as a connected device. The repeater works fine as a stand alone unit. I looked inside and it appears the the ethernet cable plugs into the borad mounted on the power supply/receivere and then another ethernet cable connects to the front circuit borad. I replugged in all the ethernet cables, trying a different cable (externally) and a different ethernet port (even connecting directly to my router), but still cannot ping the repeater. Anyone have any other ideas?
