XTL 2500 swapping
MTS2000des
5B2_BEE00 Czar
What he said, If you are swapping control heads, the one thing you may run into is TIB/CHIB compatibility and radio firmware ideally should at the same release as the control head or higher. If lower it may produce a mismatch and the head won't communicate with the radio brick. The DSM is good reading.
