Xtl 5000 Hhch help
Matt9638
My radio handheld control unit is not turning on. When I push the power button the green light comes on but no display
riveter
MD
Do you get any other indicators of correct powerup? Beeps for channel changes, etc? If not, check ignition sense.
KE4ZNR
Radio Guru
Could be inhibited. Were you trying to affiliate with a trunked system? And are you authorized to be on said system?
Marshall KE4ZNR
Matt9638
Yes it had a trunk system in it, but as I was changing zones I believe it shut off. The 3 zones on it that were trunk I never even use. If deleted would it work.
Project25_MASTR
TX-COMU
Texas
Which control head? Sounds like a classic loss of ignition sense on a W3 or a corrupted codeplug (my Astro Spectra Plus did that when you plugged in the programming cable before powering on the unit).
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Were you authorized to be on that system? If not, it does sound like your radio was inhibited.
Unfortunately, you'll have to deal with uninhibiting the radio first before you can do anything else with it.
KE4ZNR
Radio Guru
Having inhibited a few radios here and there I too believe this might be the issue hence my initial post.
Marshall KE4ZNR
Matt9638
W5pky I have the O3 head. I think it is inhibited. Hooked it up to programming and would not read. Anyone know how to uninhibited the radio
trumpetman
Charlotte, NC
You can still read an inhibited radio, so that may not be your issue after all.
If it has been inhibited you need to contact the system admin. If your radio is authorized on the system then it shouldn't be a problem at all to re-enable it.
N4DES
Retired 0598 Czar ÆS Ø
South FL
Are you using a serial programming cable? I have an XTL5K in VHF with an O3 head and I can only use a serial cable on it. I get a warning box and cannot read it with a USB cable.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Aha!
Typically you get a NO USB indication on the display but if you don't have a display because your radio is inhibited, you probably wouldn't see that message.
Matt9638
I use a serial to USB adapter. I also programmed the radio previously using this.
