XTL or Astro Consolette Cross Patch
kcarrington
Red Lodge, MT
Anyone have info on doing and XTL - XTL or Astro Consolette - Consolette cross patch? I need one to be P25 and the other to be trunked. Will be a two way bridge. I have plenty of either XTL or consolettes to do this, but want to do it right. TIA
merlin
DN32su
The cross patching itself is as simple as installing for a repeater.
Each system though would have to be configured to work both ways via the cross patch.
Dig up all the documentation you can for the consolettes, installations, and configurations.
Then you need the same for each of your different systems.
What about dispatcher consoles ?
kcarrington
Red Lodge, MT
I've got several radios, just trying to find the safest and most stable way of doing that actual COR detect from radio 1 <> 2, the audio rx, tx, ptt are simple, just don't want to try anything if that makes sense.
MTS2000des
5B2_BEE00 Czar
ASSuming you're patching a repeater to a P25 trunked talkgroup, you really need a radio gateway to prevent "ping ponging". You did say, "do it right" correct? A simple two port radio gateway would accomplish this.
kcarrington
Red Lodge, MT
Thanks, that's what I was thinking. Any recommendations on brands or any you've used in the past?
littona
Super Freq
Council Bluffs, IA
Thanks for the recommendation! Just got a contact form submitted to them.
We have about 50 of them deployed to date. They work really great and have a bunch of flexible connectivity options. In our case, we use them to connect radios at remote locations back to our dispatch console system over VPN internet connections (via SIP). But if all you want to do is patch two radios together, it'll do that easily. The basic model with 2 radio ports activated runs about $2622.
Hint: you can buy the radio interface cables from them, or just go to the source and save some money.
Hall Electronics Inc. https://www.hallelectronics.com/ They average about $125 each.
kcarrington
Red Lodge, MT
I appreciate the info!
