XTL Remote Head Programming (Best Practice Advice)
A question for the Motorola pro's out there. I have a XTL5000 currently being used with an O3 control head. I can't easily access the rear port for programming any longer the way the radio is setup. I am wondering what (if there is) the preferred option is.
I have the old O5 head with HLN6912A and could run the HKN6169B (blue cable) to it and program through the front port with my regular programming cable I use for my other XTL2500/XTL5000 radios.
OR
Would something like this cable I found work through the parallel port on the TIB? For Motorola XTL5000 XTL2500 APX7500 DB9 COM Programming Cable 9 Holes to 25 Pin | eBay. I haven't found much information on this method or a Motorola equivalent part number.
From what I can find, I'm spending $45-60 either way, just wondering if there is a better method.
Thanks for all any input.
MTS2000des
5B2_BEE00 Czar
If you use an O3 with an XTL, you can't use a USB anything. You'll need a serial GCAI programming cable HKN6183 will work.
Edit: I'm dumb, I understand what you're saying, go through the TIB GCAI directly. I seriously don't know why I didn't consider that. Thank you.
This cable finally arrived, however when I connect it, "radio failed to acknowledge" using COM1 as my port. I've used that COM port to program other radios, including this one, but with via the rear accessory port.
Edit: I can read another XTL5000 with an O5 head through it's GCAI so the cable appears to be in good working order., TIB P/N is PMLN5038A.
nokones
Timeout for bad behavior
Sun City West, AZ
I believe the HLN6912A is a M5 controlhead for the XTL2500. The M5 will not directly play with the XTL5000 unless the specific modification is applied to the controlhead. Apparently, it is a simple mod and there has been several posting regarding this subject.
The HLN6912A is a M5 controlhead for the XTL2500. The M5 will not directly play with the XTL5000 unless the specific modification is applied to the controlhead. Apparently, it is a simple mod and there has been several posting regarding this subject.
I have the CHIB with part number HLN6912A coupled with an O5 style XTL5000 head and it worked without issue. No modification needed.
I did not get it from this seller, but this would be an example: Motorola HLN1468A O5 Remote Head for XTL5000 05 w/ Chib Remote Mount | eBay
N4KVE
PALM BEACH, FLORIDA
55engine
Hartford County area
I just bought one cause I installed an 05 remote head for my XTL 2500 and my apx 7500 wait for it to come in
