XTL2500 and HLN6042A
dennhop
We just received a XTL2500 with an HLN6042A as a station tone dispatch from our county dispatch center. We are a small rural fire department in Indiana. What I was trying to find out was what the impedance rating on the speaker in the HLN6042A was, if anyone happens to know. A brief search here on the forums as well as on google failed to provide that information. The reason I'm trying to locate that info is I'm trying to figure out the easiest way to add a few more speakers to the unit. Currently, it sits in the office, which is fine if we're in the office, but I'd like to be able to add a speaker to the vehicle bay. The easiest way I can think of is if I can find out what the impedance on the built in speaker is, then if I can find three more with the same impedance rating, I can run two in series and two in parallel off of the back factory connection, adding a total of 4 speakers while maintaining the exact same impedance, and avoid damaging any of the circuitry in the amplifier.
prcguy
The best way to add all those speakers is to put a 70 volt line transformer at the radio and matching transformers at each speaker. The 70 volt line transformer has a high impedance output and the corresponding transformers at each speaker have a high impedance input reducing speaker wire loss on long runs. These transformers usually have taps for different power levels to the speaker so you can have one radio volume setting and some speakers downstream can be louder than others depending on the tap used.
The Motorola speaker is probably somewhere between 4 and 8 ohms but that won't matter when using these transformers, just wire them all up and it should work ok. I would recommend using a high efficiency horn type speaker to cover a large area so it can put out a lot of acoustical energy without taking a lot of power from the radio. The stock Motorola speaker should be fine near the operator like in a dispatch area since it doesn't have to get very loud.
