XTL/XTS5000 XTL2500 Dash mount not powering up
LCT123
I have 2 XTl 2500 under dash mount radios that I can't get to power on. I have the ignition sense plug on the back of the radio connected to the battery with the main power cord. Radio will not power on. Am I missing something here? Radios were given to me and I was told that they work.
a417
you've verified power at the connector for both the power connection, and pin 25?
Bad wires happen.
LCT123
Bad wires happen.
Yes I did. Checked with volt tester, connected to truck battery and an inside 12 volt power supply. Only one wire coming out of the ignition sense plug, and its plugged into slot 25
