XTL5000 From Channel MPL not working as I expected
casper809
I have an XTL5000 with an O5 head. I was hoping that on MPL capable channels that the MPL selection for a specific channel would be retained independently from the MPL selected on another channel. I have "From Channel" selected in the MPL Recall Mode option but the radio stays on what ever the last selection of an MPL was on any channel. So if I select MPL 1 on one channel then go to any other MPL capable channel it will also be set to use MPL 1. If I then select MPL 2 on the second channel and go back to the first channel it is now also set to MPL 2.
(From RSS Help File)
MPL Recall Mode (Conventional Configuration, General)
From MPL List: The radio-user's most recent MPL List selection applies to all of the radio's Conventional dispatch channels.
From Channel: The radio-user's most recent MPL List selection applies to the radio's current Conventional dispatch channel only; therefore, it is possible for different MPL List selections to apply to different channels.
As far as the firmware, this radio is showing the following:
DSP Version: R170100
CH Version: R13.00.01
Does the feature I am trying to get to work require a newer firmware version?
