XTL5000 Power Setting
W0RS
Nixa, MO
I have the XTL5000 programmed with the CPS and found the setting for the min and max power level settings. My question is, where on the radio control head would I have the option of setting either low or high? I would hope I would not need to go back to the CPS whenever I want to change it, kind of inconvenient…….:)
Veclesus
You set default power setting in each personality, however you can add a PWR menu option, or set a button to H/L to manually change power settings.
