XTL/XTS5000 XTL5000 with W4 Head problems
jtm1816
Martinez, GA
Having an issue with an control head change.
Originally had an XTL5000 with O5 head. Worked great but i wanted to switch out for one of the W4 heads so i could sell it to a friend. Purchased the correct Tib, Chib, and flex. I ended up creating a brand new codeplug and reflashed the radio just to make things easier. When the radio is powered on, the control head comes up with the correct display, however the XMIT button stays lit up red and will not let me transmit.
I have checked to ensure that the radio has "secure equipped" not checked
Is there anything else i should be looking at?
a417
Do you have the emergency jumper in J2? if you change the head back to the O5 with the correct setting in the codeplug, does the radio behave normally?
jtm1816
Martinez, GA
Sorry i forgot to Mention these are in a remote configuration so nothing is plugged in to the J2 connector. I haven't changed back to an O5 head just yet, i was considering that a last resort
a417
I always jump out the emergency pins on all my installations. I just gave 2 seconds worth of seaching thru the BSM and installation docs I had, and it suggests connecting (or jumping out) the emergency button/MDC activation line - but it doesnt seem to explicitly state it needs one. It's been far too long for me to remember if the silent emergency displays "EMERGENCY" on the screen when it's tripped or not. Is silent emergency enabled in the codeplug?
jtm1816
Martinez, GA
When i had the O5 head connected i didnt jump it and it worked fine but who knows that could very well be the issue I did check and silent emergency is not on. Its strange that i can change the channels, zones, and all but it looks like it is constantly trying to transmit
a417
Does this constant XMIT light continue if the W4 is on another body? I'd jump it out first, then swap it to another XTL (if avail) to see if the problem follows the radio, the head, or the codeplug
clbsquared
Isle of Wight County
In the remote head configuration for an O5 head, the rear accessory connector is not used, therefore it isn’t necessary to jump those two pins.
jtm1816
Martinez, GA
I tried switching it to another radio and it caused the same issue. I am definitely under the belief that it is the heads that are the problem. Unfortunately I am at a loss as to where to go from here
jtm1816
Martinez, GA
I read through the installation manual and it says that when in remote configuration for the W4,W5,W7, and W9 the emergency jumper moves to the control head
