XTS 1500 NO RX
rich1125
CURRENTLY I AM PROGRAMMING A XTS 1500 VHF WITH FREQWENCY OF 152.42750 WITH A DPL OF 703 AND A TRANSMIT OF 157.68570 DPL 703 IS THE SAME AS RX, I CURRENTLY CAN TRANSMIT BUT NOT RECIEVE ALL I GET IS A BLINKING LIGHT ON TOP. IM USING AND UNMUTE STD MUTE WITH A SQUELCH FINE TUNE OF 6 NON ASTRO. BUT IF I USE CSQ I GET RX NO PROBLEM BUT A TON OF BLEED THROUGH FROM A TAXI COMPANY . CAN SOMEONE HELP ME ON THIS IM SO LOST ON WHAT I DID ANY HELP WOULD BE GREAT THANK YOU .
Sounds like you have the DPL set incorrectly on the RX side. Confirm the setting in the repeater and make sure it matches what you are programming in to the radio.
As for the "bleed through" of the Taxi company, are they licensed on the same channel as you?
Do you have your channels set for 12.5KHz/2.5KHz deviation?
rich1125
I HAVE 2.5 SET DEVIATION OK I WILL CHECK THE REPEATER RIGHT NOW I WILL LET YOU KNOW.
If the LED lights up on your radio when the repeater is transmitting, then the receiver is hearing it. Something is keeping the squelch closed. Usually it's the PL or DPL set incorrectly.
As for your Unmute/Mute rule, should be set to Std Unmuting, Std Muting, unless you are using some form of paging.
rich1125
NO FORM OF PAGING JUST MDC IT SHOWS ON MY OTHER RADIO 703 DPL WHICH IS A HT 1250 WHICH IM BAFFLED BUT I DO HAVE IT SET ON UNMUTE / STD MUTE I DOUBLE CHECKED ALL RX /TX DPL CODE REPEATER ON FCC IM LOST SOUNDS CRAZY BUT IT HAPPENING . SHOULD I TRY MIXED MODE .
MTS2000des
5B2_BEE00 Czar
YOU DON'T HAVE TO SHOUT
Ahem...if the DPL/PL mute rule is set to "standard" and other subscribers unmute, than it's possible your XTS needs an alignment. The XTS/XTL are also very sensitive to DPL deviation, if it's too low, it will ignore the code and remain muted if RX is set to decode.
rich1125
sorry i hit caps lock
rich1125
wow that i did not know whats funny is if it blinks red and i hit the ptt i can get the transmission
rich1125
Just remove the tone. It ain't gonna help the bleed over.
Frank
so just take the rx out and put it to csq i think i will cant figure out why it will not work sounds crazy never had this before.
ramal121
Lots and lots of watts
Calif Whine Country
That is normal operation if you have another type of signalling squelch enabled. You mentioned MDC. Do you have Sel Call enabled?
rich1125
yes i do have it enabled i forgot to also put its a 1.5 model. could that be the issue i have it set to sel call .set to std mute dpl are all correct and i have it set to non astro im just baffeled .any help wold be appreciated.
ramal121
Calif Whine Country
In your personality if either Sel Call Decode or Call Alert Decode is checked, then uncheck it.
rich1125
Frank
het frank you helped me awhile back on my xts 1500 rx issue i have on csq it works great got it tuned alinment but if i put tone in agian no rx , i dont mean to beat a dead horse but could the board be bad . thanks richard
Who tuned/aligned your radio?
If the 'board was bad', then that would have been discovered during the alignment process.
Compare your codeplugs carefully. If the HT1250 works, and you copied the settings —exactly— then there's an issue with the radio.
rich1125
it was done by a motorola dealer thank you i will appreciate all the help .
