XTS 3000 programming hardware
kv5e
T¹ ÆS Ø
XP VM on Windows 7 Professional 64bit will work with a serial port.
Box is an Ivy Bridge E with 64 GB of RAM, spawn a XP VM and you are good to go.
topdog1198
topdog1198
OS
Not if it's a 32 bit version of Windows. 64 bit is what doesn't work correctly and gives the error, cannot communicate with device.
Yes its Windows 7 64 bit is what I have . but i got a Dell D620 running window XP Maybe that will work
thanks for the help
topdog1198
topdog1198
I've been programming my 5000 for a little while just made the purchase of a 3000 purchase the software now looking for the hardware interface. I see quite a bit of stuff on eBay but don't wish to waste my time buying junk. Does anyone know where I can get the correct rib box and the cable? I've already purchased one off of eBay it doesn't seem to work I keep getting an error message that is not communicating with the radio, so I'm thinking may be a bad boxer cable any suggestions
Thanks in Advance
Update I want to thank all you guys for the help. Someone here suggested what type of computer to get running Windows XP I got one for about $39 it was able to program the unit in the matter of seconds once again I want to thank everybody who offered help and advice 73 s
topdog1198
topdog1198
Dell computer
Dell Latitude laptops like the D620, D630, D830, etc. are ideal for radio programming. They sold truckloads of them and they're cheap, plentiful, reliable, nearly bulletproof, and if they do have problems, spares are cheap and plentiful, too.
Thank you very much for your help. Because of your suggestion particular on what type of computer to get I was up and programming in a matter of minutes
Thank you so much sir for your help
