XTS 5000 Control channels Values ???
underlift
Canada
When I try to program my xts5000 700mhz apco 25 control channels and I put the proper values in it goes red in all 4 systems and the Icon show RED in a system I'm trying to set up for receive only.
any help would be apprecia:confused:ted
underlift
Canada
I was able to Change the astro 25 channel ID to a +45.000000 in the transmit offset and now only the receive frequency control channel box's are still in Red, any idea's how to fix that?
thanks
jim202
New Orleans region
thanks
It sounds like you may not be an authorized user on the system and have little or no experience on how to program the radio. If your not an authorized user, given enough time, the system manager will brick your radio.
You might be better of going to the radio system manager for the system and having that person send you to the radio shop to get the radio properly programmed.
A radio not programmed correctly on a trunking system can cause operational problems to the system.
KevinC
32D2T/957.282
I'm everywhere Focker!
The base frequency has to be equal to or lower than the control channel frequency.
And if it doesn't match what the system is broadcasting your radio won't function properly.
And I agree with Jim, get it done right so it doesn't cause problems for authorized users.
underlift
Canada
Thanks for all your help, I've been programming radios for a long time now (dos)just not familiar with the new CPS's and I agree that if the radio's are not done right it can cause interference with the system but the radio that I'm programming will not affiliate with the system set only to receive but I got it figured out now
Thanks KevinC you were exactly on the money, just after I wrote that post i went over the settings and found that out.
And Thank You Radio Reference and all its members
underlift
Canada
If your not interested in helping members, you should not reply at all!
"ElroyJetson Without system keys you'll have no success. Not possible to program trunking data without system keys. You're not going to get any system keys via any official channels".
If I didn't have a system key I wouldn't be able to change any of the Values
thanks again
