XTS ABC Scan Question
northwoodsradio
Quick question, looking for a refresher again.
ABC knobs on CPS, for scan off, on, and edit.
For edit again on a 1500, what’s the command selected for select and then a toggle off/on selecting channel to scan.
VHF analog & P25 conventional
n3obl
ØAES-1056
PA
The abc selector is program via cps for whatever setting the system wants. You need to check with your admin as to how it’s programmed.
K2NEC
5F6
I believe OP is asking how to add/delete members from a scan list on a 1500 if "C" is programmed for scan list edit
Giddyuptd
Here and there
With ABC
A Scan
B Blank
C Prgrm
Purple button as a unprogrammed or blank. If I recall it will default use this button anyway as select button while in scan program.
When in program the led should emit green om channels in list. Press purple and the led should go off indicating Chanel is now out of the current scan list. Once done switch to b or a and it should save changes.
This applies to BN.
I believe AN is same though I think it does not emit the led therefore on AN versions it's tricky and you have to basically remember what is and what isn't in the list. Probably write down such as zone A ch 3 off or zone A ch 8 on etc.
